Wishes
Automatic Dimensions in Section for Complex Profiled Walls
For this helpful feature Automatic Dimensions in radial Dimension type we found it works well with composite wall/slab in plan and section but for complex profiled wall it works only in plan so we got a workaround to get it in section for now as clarified in the post below, if useful enough to be effective in Sections for complex profiled walls will be an advantage.
https://community.graphisoft.com/t5/Document-Visualize-forum/Automatic-Dimensions-Grabbing-in-Plan-b...
AC 27 INT 5003/WIN 11
Minh Nguyen
Thank you for sharing the idea, we truly appreciate the time you've taken to contribute towards the development of the software!
I'm glad to say that we took notice and we have added this wish to our Wishlist database.
(For future reference, you can refer to it as IDEA-11922)
I hope we see this get implemented in the future.
Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Minh Nguyen
Have a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Thank you so much for all Graphisoft people.
