Wishes
Automatic responses to error/warning messages
Haneef Tayob
I'll often start a process that I know will take some time (such as publishing or opening a large teamwork project).
I'll then often step out to do something else (meeting, coffee, etc)
Quite often when I return, I expect to find the file open and ready for me to work on, but instead I'll find an error or warning message. Often one would simply click continue, yes, ignore, update, etc.and then wait for the process to complete.
I thought it would be great if when an error message lists and there is no response for say 10 minutes, it defaults to a preferred answer that one could have set in settings.
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
1 REPLY 1
I believe if you turn off the error messages in the Work Environment then you will not be stopped.
Of course you won't see any of the error messages which could be a bad thing.
