2017-02-09 06:33 AM
2018-09-27 10:03 AM
2018-09-30 03:37 PM
2018-10-03 04:15 PM
2019-11-22 09:29 AM
2019-11-25 02:18 AM
AvrilP wrote:
I require Autotext ability in Layout Setting, to add #RevID to the layout name when publishing. Please!
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2019-11-27 07:57 PM
2019-11-27 11:17 PM
2021-03-06 02:32 AM
mbl wrote:This works very well for individual pdfs if you use "Rename Items", however if you select "Merge to 1 pdf" it will only save the folder name, not the compiled name, If we could use the same format for folder names or sub folders this would be excellent....
Items and folders in The Publisher Sets are actually the only place in the Organizer that accepts Autotexts.
So yes, you can get pretty much any Autotext from the Project Info as the name of your file or folder. You just need to rename the folder or the item manually. Just right click on the folder/item, select Rename Folder or Rename Items and under Custom Name write something like "<SITEADDRESS1>, <SITEADDRESS2>, <SITEADDRESS3>, <CLIENT_GIVENNAME>".
A very useful list of all these Autotet keywords is here: https://helpcenter.graphisoft.com/user-guide/65541/
2021-03-15 04:21 PM
DJ wrote:If you don't have any "parent" folder that has the merge option on, then the "autotext" works for renaming the sub-folders as well and it will save the sub-folder name with autotext as the PDF's filename.
