2019-02-26 11:08 AM
2019-02-26 06:15 PM
2019-02-26 06:15 PM
2019-02-26 07:19 PM
KrisM wrote:If you have access to the US library, all of the RoofMaker parts have fills, like Beam RM22, as does the Joist Beam 22 object, and there are a number of third-party beams with fills. (e.g. Cadimage Objective) Basically, you need to expand your thinking beyond the Beam tool and be willing to use Objects instead.
I have a series of beams and rafters which are all modeled as beams. The rafter passes over the top of the beam. In plan view I cannot get the rafter to hide the portion of the beam over which it passes. Rafters and and beams are on separate layers with different layer priorities. I have tried different graphic overrides and display orders. The cut plane for the view is below the beams and rafters. I'm at a loss here. Maybe someone has a solution.
KrisM
2019-02-26 08:45 PM
2019-02-26 09:29 PM
KrisM wrote:
This seems to be a Archicad thing where you are presented with a number of variables which do not respond to any logical order of entry.
2019-02-27 08:14 AM
