Wishes
SOLVED!
Better DWG import/export
Why use an xref dwg rather than a placed drawing?
To take advantage of hooks and a better graphic representation.
On the other hand it is sometimes impossible to use a dwg without having to modify it before its import. Archicad's Xref function then becomes incomplete and therefore unusable.
I want the import of DWG to be as simple as using the placed drawings (with hooks)
An example about how a thermal insulator is translated by Archicad :
Only thermal insulators are exploded.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
1 ACCEPTED SOLUTION
Solution
The solution :
1 - Change "Opening options" about the DWG translator.
2 - Input DWG by Xref with the right DWG translator.
3 - Open the Attribute manager and replace the type of line concerned (mine is called "dessin2|Continu").
4 - You are able to organise your kind of 2D line translation to automatise the thrid step into the DWG translator.
We are able with Archicad to input DWG
Christophe - FRANCE
1 REPLY 1
Solution
The solution :
Christophe - FRANCE
Learn and get certified!
