matthew
i am voting "important", because batch importing is just one of a number of 'batch' issues that plotmaker has. i would like to see them all sorted out.
for example:
1. you
can't batch select files to be published to print and set the attributes all in one go, but you
can set everything except 'print options' if you select folders that contain the drawings to be printed.
2. you
can batch select and set plot files to save (PLTs), however the output is one big PLT file rather than a PLT file for each drawing.
i have experienced a few more quirks with batch selection in the publisher, but can't remember them right now . . . if i do i'll re-post here.
~/archiben
b e n f r o s t
