Wishes forum
Block horizontal undesired moves
Some times when working in 3d is it very useful to prevent the different entities of undesired horizontal displacements. Some times the pet palette switches from the "Z" value to the displacement tool, and that is very dangerous bcz if you don't realice a the moment, then will be quite difficult to correct. This is specially useful in teamwork workflows.
2 REPLIES 2
Erwin Edel
The old method of vertical displacement, Elevate (CTRL + 9) still works. Here you can input an excact number only.
Maybe this works for you, for now.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Editing mesh, sometimes is more useful work in 3d, and then is when I miss to block horizontal moves bcz is easy to make some undesirable movements if you are drawing quickly.
