Wishes forum
Boolean Operations
ares997
When you do a boolean operation it should be parametric just like the rest of the tools. For example if I use a light in a slab and remove the edge of the light from the slab it should show up as it is in 3d, with no slab where I removed it.
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
2 REPLIES 2
Thomas Holm
I'm not completely sure what you're aiming at, but I would guess what you actually mean is that SEO (solid element operations) should show in the 2D plan view as well, like in other views. I agree with that, but I think there are several wishes to that end already.
AC4.1-AC24SWE-25INT; OSX11.5; MP5,1+MBP16,1
As Thomas said, it is difficult to tell what you are asking for ... but if it is that the results of solid element operations (ArchiCAD's term for 'booleans') be seen in plan, then there is at least one wish here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=22800
already.
If that wish is what you're asking for, please vote there and let us know, otherwise, explain what you want more clearly.
Thanks,
Karl
One of the forum moderators   •   AC 26 USA and earlier   •   macOS 12.6.1, iMac Pro 10-Core, Radeon Pro Vega 64
