Wishes
Building Material Plan & Section cut fills to be seperate
Add an additional cut fill option when creating new building materials.
This feature would give us more control over how we draft.
I have set up a brick cut fill that reads as bricks should for a 1:50 or larger section, which has been saving me time in making sure that my levels, windows etc are set up to brick-scale.
HOWEVER
This does cause major issues for my walls in plan (as they are now reading the fill I set up for sections)
I am using a graphic overide on the plans to fix the cut fill, however, the graphic overide changes the entire walls hatch, not just the selected building material.
Adding a feature that allows you to set up a separate hatch for plan and section would allow for way more control over drafting.
(allowing graphic overides to effect only specific building materials, rather than the entire element that contains the building material would also be greatly appreciated.
18 REPLIES 18
Eduardo Rolon
You can use GOs to do this without much trouble right now. Though it would simplify things having the extra setting in BMats.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
gdford
Graphic Overrides will not override a building material fill in a single skin of a composite wall or slab in plan or section. This would be a really nice feature!
It would also be really helpful if the building material name of a single skin in a composite wall or slab could be drilled down to in auto-text. At the very least the list of building materials used in a composite should be available as a "string" so it can be parsed with a property expression.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
I actually like this idea, the ability to define a Floor Plan Cut Fill AND a Section Cut Fill for Building Materials. I remember users have had problems with that in the past.
Also, if this is implemented for Building Materials, then it will become available as a feature for all element types, not only for Walls (to which it is applicable).
Yes! This would be incredibly helpful! At the very least, it would be nice if you could override the fills, by CORE, FINISH & OTHER, which I think would help your situation easily. But having the option of defining a separate section and plan cut material would be infinitely more powerful. I’m new to AC... how do we get them to add this feature??? Wishlist? Do they ever implement user feedback?
-Matt
It would also allow for more accurate detailed sections. Where we could set a fill for the cut material.
p.s.: I first voted important, but thinking better I would like to make it essential. Please make that available the change of vote in the Polls Options?
DGSketcher
Legend
+1 as it would really help in live details and composite / complex profiles
-Matt
The forum software does not make it possible to change an already placed vote.
Hi Laszlo,
I think the new version can.
Oops, you are right, I was not aware of that option.
I activated it so you can change your vote now.
Learn and get certified!
