Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
COLUMNS & BEAMS VENEER
Takis
Hi, my wish is for columns & beams veneer.
Please add:
1. Veneer option for beams for selected sides.
2. Veneer improvement for columns for selected sides.
I am attaching a situation for the specific subject.
Thanks.
Takis.
Win 10 Pro
MacPro Late 2013
AMD 2XD500
16GB RAM
5 REPLIES 5
You should solve these situations by creating custom Profiles for your Columns or Beam and using those.
You can even categorize the various skins/components as Core, Finish or Other so Partial Structure Display works on them.
So I don't think this feature is needed.
Takis
Everything may be customized in Archicad.
This customization demands a lot of time and it is not effective at all and it cannot be done in every project.
I believe this tool and its improvements is a must.
Does this option in the column tool help?
Anything that is not a core in the wall composite will wrap around the column.
abdelaziz
I precised that snap does not work the turn of the composite column
AMD Ryzen 5950x
AMD RX 6750xt
AC27
No it does not work with complex profile columns.
But it does with rectangular and circular columns - with or without veneers.
In the image you showed originally you would just need a stand rectangular concrete column.
