Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
CUSTOM DOORS & WINDOWS
Leire Bilbao
There is another wish for custom casing in windows and doors, but I also need to combine "top hung" at the top with sliding at the bottom, and custom sills, and custom frames, and I want to show the double glazing when I cut it, etc... Basically to be able to easily create my own custom object without learning to script
Lingwisyer
Guru
You could grab a top hung window and gang it with a sliding window? And if need be morph them then save them as a new window?
Also for my firm is essential to see the handles in the symbolic plan view
