Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
CUSTOMIZABLE RIGHT CLICK PALETTE
We lost some options here in AC9 and it would be nice to have the right
click palette contents be editable
5 REPLIES 5
__archiben
mate - you're allowed to vote in your own poll!
i believe that the original work environment intention was for full customisable everything, including the context menu, but the reality was thousands of different context menus to configure based on (obviously) the context you were working in.
whilst i agree that several more commands in there would be nice, i think that it may actually be a case of asking for them specifically . . .
what are you missing? and are you sure that it's not simply down to the user profile you're using? try putting it into 'advanced' and seeing if that does the trick?
(by the way - you might want to check your signature )
cheers
~/archiben
b e n f r o s t
cheers
~/archiben
Why check signiture? Dont see anything wrong there
Undo and Redo are the commands I use in the right click palette for the past 5 or 6 years
Depends on if you spell your first name "Jonatnan" 😉
One of the forum moderators
Didn't see that. Thanks again Karl
In fact you can customize it
Work Envirommnet under Regedit is the key. Just be careful.
HTH
Ricardo
