2007-09-04 04:47 PM
2007-09-04 05:36 PM
2007-09-04 06:26 PM
2007-09-04 07:37 PM
Chazz wrote:I use a Dashboard widget called Case Converter when I need to convert text.... It works okay but is time consuming and annoying....
Occasionally, I'll copy/paste text from AC into my email app (MS Entourage), change the case there and then sling it back into AC. It's one of those little things you do with computers that make you feel small and humiliated.
2007-09-04 07:58 PM
TomWaltz wrote:I had the same thought but what I know is that if there ever was one, it must have been too poorly implemented or award for me to have wanted to use consistently.
I thought there used to be one. Did I imagine that?
2007-09-05 03:24 AM
Chazz wrote:No, but I've been using Copypaste for some years now.
/......Does anyone remember this?
2007-09-05 05:12 AM
2007-09-05 05:30 PM
Link wrote:Yup that was it. The suite also had a nice align feature.
Orbit Solutions used to have an add-on that changed case.
Link wrote:Impressive depth of knowledge as usual Link!! Thanks
Select some text and hit Ctrl+Shift+A (PC) and you'll see all the text turn to caps. Unfortuantely when you click out, it all reverts to it's original format
