Wishes
Change Wall Reference Line: Remember Last Setting
runxel
Legend
The wall reference line is a essential thing in Archicad, and so is the tool for changing it.
I wish to have an option (so nobody is forced to this behaviour) that the last option chosen in the dialog will be remembered.
Maybe this could go even further: Let every dialog have the option to remember its last setting.
4 REPLIES 4
I don't fully understand this wish.
Dialogs do remember their last settings. Could you elaborate a bit more?
Do you mean the "Modify Wall Reference Line" Dialog?
runxel
Legend
Yes, right. Thanks Laszlo. (Not always easy to find out, what stuff is called in the english version...)
However: No, dialogs don't remember their last settings. Just try it! You will see, that every time you open the "modify wall reference line" dialog, all options are unchecked again.
Yes, I understand now what you are saying.
What I meant is that Tool Settings Dialogs do remember their settings, but you are right, there are many other Dialogs in Archicad that do not remember their settings.
to lift up again
