Wishes
Change manager
KeesW
I'd love to see a change manager, working with Navigator in Archicad. Revit already has something like this. The idea is that different versions of the projects, or different service stages (eg Exisiting plans, Schematic design, developed design, contract documentation, etc) are stored and kept together where they can be accessed later. At the moment, it is not practical to manage these within the same model because it involves too many layers and combinations.
Cornelis (Kees) Wegman
cornelis wegman architects
15 REPLIES 15
Link
If the Search Engine was working at the moment, you could search for teamwork options. Teamwork is the best answer at the moment, it was discussed just recently.
There is also a tool called Otptions Manager in the US, but it doesn't do the job nearly as well as Teamwork IMHO.
Link.
Laura Yanoviak
<bump>
This is essential. We just finished a renovation of a high school with 7 different phases -- 'new' elements in one phase had to be represented as 'existing' (or 'non-existent') in others. It was a fast-track project -- construction was concurrent with construction documents -- once one phase was issued, the next one began without pause.
We did this with 4 different AC models and a lot of nested hotlinks. We managed to pull it off, but model management was a nightmare. An Options/Phase manager would be very helpful when dealing with:
- Existing/Demolition/New construction
- Multiple design solutions
- Projects with multiple phases, as my example above.
AC26 US (5002) on Mac OS Ventura 13.5
Erika Epstein
Wow, Laura, sounds like a very interesting case study. Care to write it up?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Laura Yanoviak
I didn't work on the project -- just made suggestions as far as how to organize the model/files for the desired result. The ideal person to write it up was just laid off (so I may just have to document the model/file structure for future reference!).
Erika Epstein
It would be interested to read your "document the model/file structure for future reference" if you don't mind sharing when you have done this.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
I have read somewhere that Revit handles phasing much better than ArchiCAD. Have others hear that? I think we too struggle with the model management nightmare that Laura mentions...
KeesW
Handling stages and options is a standard Revit feature and I wish ArchiCad had it. Some of our users say that you can do it with Teamwork but I'd like to hear an outline of how this would work.
It occurred to me the other day that the lack of a flexible way of trying out different designs and permutations was one of the main problems I have trying to 'sell' the concept of ArchiCAD to more experienced 2d CAD based colleagues.
In 2d CAD I/we often create several versions of the same elevation just to try out various arrangements of windows or roofs. This can be done quickly and simply by just copying the lines and moving then to one side, making the changes, then visually judging them against each other. In ArchiCAD there are various techniques like moving duplicates of the geometry to one side, setting up special layers, saving stuff to modules, but none of them are quick and simple and give you the ability to immediately assess that particular design in the context of the rest of the 3d model. Of course you can set an individual elev as a 'drawing' and make some 2d edits, but you will have lost the ability to design in 3 dimensions - one of the key advantages of software like ArchiCAD.
This lack of flexibility basically means that you have to have a more developed idea of the final design before you start trying to model it. Also, useful things like keeping the simplified planning model in the same file as construction model become very awkward.
A secondary layer-based system (mentioned in the middle of this thread) seems to me to be the ideal solution. The layers that control the visibility of geometry should be separate to the layers that control the design options. This would allow versions of the geometry to exist in the same place and stay on their various geometry layers, but be easily switched with another design.
This feature is essential in my opinion, and if implemented correctly it could really speed up the whole design process.
Peter wrote:
A secondary layer-based system (...) This would allow versions of the geometry to exist in the same place and stay on their various geometry layers, but be easily switched with another design.
Curiously I was thinking about this the other day and came up with an idea:
Why not having the ability to assign an element to more than one layer?...
So we could just create a layer "Version 1" and assign all the element related with it... but keeping their logical element/layer definition.
Does this make sense?
Learn and get certified!
