Wishes forum
Collapsable folder levels in Navigator, Organizer
Ignacio
I would like some little arrows up top that would allow me to open/close (they would probably be used almost exclusively for 'close') project map, view map, layout map, publisher levels in Navigator, Organizer. With long lists of nested items this should speed up navigation by a lot.
In reality what I would really wish is the option of something like the columns view in MacOS Finder but that must be difficult so.
11 REPLIES 11
i have them mapped to a key shortcut. and i am pretty sure what you want is already there in some form. a screen would help for sure.
FREE Soffit & Fascia for Rail Tool - https://bit.ly/BIMRithmSoffitandFascia
FREE wall Accessory framing and coverings - bit.ly/BIMRithmWallAccessories
FREE Truss object - https://bit.ly/BIMRithmTrussV1
FREE Custom Tube Object - https://bit.ly/BIMRithmPolyTube
AC 24, Twinmotion current, Windows 11, Msi 10UG with rtx 3070, wacom intuos pro m, Wacom Cintiq Pro 16, razer Tartarus pro.
Something like clicking on black arrow (colors for the sake of this explanation only) collapses/expands everything to level black, red to black+red, green to black+red+green, etc.
It could apply to whatever you have selected; so that by selecting a red item you could either collapse it into itself by clicking on the red arrow, or expand it down to whatever downstream level you want by clicking on the others. Something like that.
Working views
- Working plans
- - 1st floor plan
- - 2nd floor plan
- Working model views
- - exterior front
- - cutaways
- - - cutaway 1
- - - cutaway 2
Schematic Design
- General
- - whatever
- - whatever 2
- Plans 1/4
- - 1st floor plan
- - 2nd floor plan
11111.pngso folders and subfolders?
The wish is a mechanism for collapsing/expanding the folder structure to a given hierarchical level.
As I said, this is my diffuse idea for doing something like columns view in MacOS fInder, there may be some other ideas for allowing better navigation through long lists of items in multiple levels.
I gave up on Mac long ago, but I am guessing your text description is not what I think it is, to me the current structure is what you are asking for.
I am interested as I love easier navigating. But again to me what your wishing exists based on text alone.
i think what he's asking for is an ability to collapse/expand multiple subfolders at a click of one button
the screenshot above is probably some kind of over-kill, but essentially the higher the folder you scroll up, the more expand/collapse sub-folder buttons will be seen where it will collapse/expand the all sub-folders with the same hierarchy, instead of having to click the up/down arrow for every single subfolder at each level.
AC22 | Win10 | 64 bit | 16Gb RAM |Intel i7 8700 @ 3.20Ghz
If the levels are tabbed, which they are now, one only needs buttons at the frame top, at the table header.
JaseBee
Hold the "option" key and click the expand/collapse arrow to expand or collapse all levels beneath it. (for OSX, not sure if there is a windows equivalent)
AC 24 5004 AUS
iMac OSX (10.13.6) 4.2ghz i7
8gb ram/8gb vram
I am aware of option click. What I wish is not option click. Long lists remain impossible to navigate with option click. Current list with collapsable items only is fine for 20 items. Large projects with long processes result in unmanageably long lists. Am I looking at a 1/4" floor plan from SD, DD, City, is it design option 1 or 2, etc. I need to collapse the list to 2 or 3 levels up to know where I am. I can't read the tree structure in a scroll. I can't zoom in and out of level hierarchies in a scroll.
Ive been trying the option click functionality, something I had forgotten and only recently re-learnt.
I understand your request as more control equates to better faster outcomes but I have big folders too in my projects but I try and keep the structure as efficient as possible. Reduce the qty of nesting folders in the tree and organise folders with codes may help in the interim. I find i can collapse and dive in and out of folders using option click quite comfortably if its two folders deep.
The other thing i find is that on my laptop due to screen real estate, organiser/navigator offers very little size so navigation is a nightmare. On my bigger monitor 32" at 4k resolution its less an issue because i can have so much open at full expand.
The complex solution may not be the best route, I try to think outside the square lots and to me it's a GUI software design problem. lots of little pallettes and docks to click in and out of. Why not let us have the entire work screen such as a tab to use where as you say we have folders similar to how macs work on finder or windows in explorer or multiscreen arrangements like apple spaces windows desktops etc. its the forever constant scrolling of the mousewheel to slide up and down through list but thats just an issue with computers in general.
AC25+earlier - Monterey 12.2.1 - 2021 Macbook Pro16 / M1 Max / 32GB
this is an awesome wish. something i would pay to upgrade for.
