I would like to see an option where one can choose which sides of the column should have the veneer.
It would be even better if one could also vary the thickness of the veneer around the column.
We often have situations where we might start with a column clad all around with face brickwork. As the project progresses, we end up needing to remove the cladding to the inner face and I then have to totally remove the veneer and add a wall.
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
