Wishes
Column Veneer - choosing which sides
Haneef Tayob
I would like to see an option where one can choose which sides of the column should have the veneer.
It would be even better if one could also vary the thickness of the veneer around the column.
We often have situations where we might start with a column clad all around with face brickwork. As the project progresses, we end up needing to remove the cladding to the inner face and I then have to totally remove the veneer and add a wall.
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
1 REPLY 1
Gerald Hoffman
Great idea!! Voted Essential.
Gerald
"The simplification of anything is always sensational" GKC
AC 25-4013 USA, CadImage Tools
2019 MacBook Pro 16" w/ AMD Radeon Pro 5600M GPU
OS X 11.6
2.4 Ghz 8 core i9, 64 GB RAM
27" LG 5K Monitor
