2020-01-23 12:49 PM
2020-01-23 05:18 PM
2020-01-24 02:59 AM
2020-01-24 03:26 AM
2020-01-24 07:33 AM
Barry wrote:I think it's quote possible that GS will totally redo this feature so we will have a more custom LOD system.
I know it is probably not quite the same, but you do have Partial Structure Display available if you set your CP fills up as core, finish, other.
2020-01-24 08:14 AM
2020-01-24 09:04 AM
Braza wrote:I think this is essential.
I wish Complex Profiles could have internal layers for different LOD (Levels of Detail).
As CP has been recently improved with offset modifiers, the complexity of some CP could be better handled with internal layers that could be controlled by MVO.
2020-01-27 02:50 AM
DGSketcher wrote:Ideally, the best solution would be to Archicad automatically draw a "raw" fill/BM with the external contour of the detailed CP. And then users could edit it freely, as it happens with Stretch lines (which are draw automatically if the user delete the original. I think it wouldn't be hard to implement with API.
I guess for consistency the solution is possibly the same where you set the CP scale / LOD and draw the required fills to suit.
2020-07-09 04:58 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-07-13 04:01 AM
