Wishes forum
Complex Profiles with LOD
I wish Complex Profiles could have internal layers for different LOD (Levels of Detail).
As CP has been recently improved with offset modifiers, the complexity of some CP could be better handled with internal layers that could be controlled by MVO.
9 REPLIES 9
I know it is probably not quite the same, but you do have Partial Structure Display available if you set your CP fills up as core, finish, other.
Versions 6.5 to 25
I understand Barry, but I was referring more to the complexity of the CP itself.
For example: I can create a very detailed CP with lots of of fills/BM, voids, fixings e etc, that are useful in sections, but in elevations and perspectives are just adding loads of polygons to be calculated that in the end wont be visible.
It would be good to have an alternative "layer" in which I could draw a single fill/BM and break its surface to match the higher LOD. The end result in 3d would be exactly the same, but with way less polygons.
Does this make sense?
DGSketcher
+1 Makes sense to me.
GS have touched on this with their library part maker which allows for scale sensitive components. I guess for consistency the solution is possibly the same where you set the CP scale / LOD and draw the required fills to suit. Seems like a good solution and as you say it could dramatically reduce the polygon count in rendering drawings & images. If we continue down the route of what I hope will be live details then this probably needs implemented soon.
Apple iMac macOS Monterey / AC25UKI (most recent builds)
runxel
Ace
I think it's quote possible that GS will totally redo this feature so we will have a more custom LOD system.
(I mean, it isn't even working currently with the stairs e.g., so something needs to be done)
AC 24 [ger] | Win 10 | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Partial Structure Display is another story/mess (Like Renovation Filter. Which apparently is one of the main reasons of current AC23 issues)... I have already expressed my opinion here
But LOD in CP could coexist with my proposed Property Filter View Option.
henryL
I think this is essential.
Ideally, the best solution would be to Archicad automatically draw a "raw" fill/BM with the external contour of the detailed CP. And then users could edit it freely, as it happens with Stretch lines (which are draw automatically if the user delete the original. I think it wouldn't be hard to implement with API.
Minh Nguyen
Graphisoft Moderator
Hi All,
Thank you for sharing the wish and voting to share your opinions!
I'm happy to say that, this is an existing wish in our database (please refer to it as #11976). Hopefully, our Product Management team will consider implementing this one in the future!
Thank you all once again, and have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Thanks Minh! Much appreciated.
