Wishes
Complex profiler in the shell tool
abdelaziz
It would be nice to introduce the complex profilers in the shell tool
-This would make it possible to exploit the data of the complex profile on varied construction plans
-This will improve the possibilities of architectural design
-Is my most expensive wish is to be able to convert a wall into shell
AMD Ryzen 5950x
AMD RX 6750xt
AC27
abdelaziz
one line that manages the height of the profile and the other to trace the road to go
AMD Ryzen 5950x
AMD RX 6750xt
AC27
jorgebeneitez
Hey! I also think this is a very important one but I'd explain it in a slightly different way.
I think we need a new "structural profile tool" something that can avoid the geometric limitations of beam/column and that can access saved complex profiles. Just a 3d polyline (if could be nurbs would be amazing) that is the rail for a swept profile.
In the new architecture sometimes columns become beams and vice-versa. This problem is specially relevant when working with the Grasshopper Connection.
Jorge Benéitez
M.arch | Registered Architect | ARB
BIM Implementation | Graphisoft Registered Consultant.
