Wishes forum
Complex profiler in the shell tool
abdelaziz
It would be nice to introduce the complex profilers in the shell tool
-This would make it possible to exploit the data of the complex profile on varied construction plans
-This will improve the possibilities of architectural design
-Is my most expensive wish is to be able to convert a wall into shell
AMD Ryzen 3900x
AMD RX 6750xt
AC26 Build 4019
2 REPLIES 2
abdelaziz
one line that manages the height of the profile and the other to trace the road to go
AMD Ryzen 3900x
AMD RX 6750xt
AC26 Build 4019
jorgebeneitez
Hey! I also think this is a very important one but I'd explain it in a slightly different way.
I think we need a new "structural profile tool" something that can avoid the geometric limitations of beam/column and that can access saved complex profiles. Just a 3d polyline (if could be nurbs would be amazing) that is the rail for a swept profile.
In the new architecture sometimes columns become beams and vice-versa. This problem is specially relevant when working with the Grasshopper Connection.
Jorge Benéitez
M.arch | Registered Architect | ARB
BIM Implementation | Graphisoft Registered Consultant.
