2006-04-18 09:09 PM
2006-04-18 09:16 PM
2006-04-18 11:35 PM
2006-04-19 12:37 AM
Ian wrote:what you're after - and this is a long-standing wish i have too - is true material-driven attributes. you set up and manage materials along with how they're represented in all views - plan, section, cut, uncut, 3D window, rendering, schedules, etc, etc . . .
When I cut through a "composite" wall using the marquee I would like to see the individual wall make up including any air space within the composite. At present all I see is a solid fill.
2006-04-19 01:22 AM
2006-04-19 03:06 PM
2006-04-19 08:59 PM
Graham wrote:I won't disagree with your wish. But, at least solid element subtraction provides a very usable workaround for the above. (Live, editable skins would be better of course!)
At present the project that I am working on has a lot of retaining walls, therefor the base level of the internal block needs to be set to the ground bearing slab and the external brick needs to start at the top of the retaining wall, similar issue at the head of the composite wall, the internal block finishes at the soffit of the beam and the external brick goes past.
2007-09-15 05:05 PM
2007-09-26 04:21 PM
