2005-11-29 06:14 PM
2005-11-29 07:14 PM
Chris wrote:Hi Chris,
Wouldn't it be nice if thickened lines in composite constructions actually showed in true weight views?
2005-11-30 10:33 AM
2005-11-30 02:27 PM
2005-11-30 11:43 PM
Chris wrote:chris - i'm not getting any problems at all. are you sure you're not getting 'true weight' and 'bold cut line' mixed up? 'bold cut line' bears no relation to 'true weight' - it simply thickens a hairline element's contour line if it is being 'cut' by the plan section.
Unfortunately .... no! The obvious override is not the problem. Here the line type as described in the composite set up, taking all the composite settings for line syle and colour, still allows a thinner line to overwrite the thicker line. Totally illogical.
