I am modeling a simple and standard concrete curb and gutter for the edges of a parking lot for our building site. Ofcourse the lot is not dead flat, it has fairly steep slope for drainage.
I can model the curb/gutter profile with the Profile Manager and the wall tool to layout the curbs. As long as the curb can be modeled flat, not a problem, it works great especially at corners and radiuses. The moment the curb has to be put in on a slope, the tool no longer can do what it needs to do, meaning you cant slope curb profile parallel to the slope of the grade.
Conversely, I can model the same profile with either the Morph tool or Shell tool (which is an overly complicated tool). The Morph tool will not allow easy miters at intersections points, like the wall tool will allow and in plan view. The morph tool represents the curb graphically, completely different than does the wall tool with same profile, that should not be the case. The Shell tool is the worst in plan view as it oversimplifies the profile.
However, both the Morph tool and Shell tool allow you to pull up an elevation or 3D view of curb profile modeled and rotate or slope the profile to match the slope of the adjacent grade.
In elevation, section or 3d view, you cannot rotate the wall tool to make it parallel adjacent to the slope of the adjacent grade......When, if ever, is GS going to design the Wall tool, Slab tool, Roof tool, Beam tool, with the same ability to rotate in 3D, elevation, and section, as with the Morph and Shell tool, so we can eliminate geometry limitations in our design models.
I find this to be a weakness that has existed for too long with AC.
Robert Mariani
MARIANI design studio, PLLC
Architecture / Architectural Photography
www.robertmariani.comMac OSX 13.1
AC 24 / 25 / 26
