Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Convert morph faces to walls/slabs/roofs/curtain walls/shell
TMA_80
I think this is an important step for the morph tool ( if it is aimed to be used as a massing tool )
this feature ( converting faces into construction elements) is present in Revit and was with the old sketchup Plugin for ArchiCAD.
this step was already asked for the shell tool but it makes more sense with the morph tool
AC12_20 |Win10_64bit|
25 REPLIES 25
You can get volume and surface of a morph, explain more about what you want! A solid morph should act as a wall? Or a single polygon should be able to convert to a wall?
TMA_80
More on that side.
My addition to the wish:
Not only a single polygon, but basically any curved or double curved surface or any kind of non-regular surface can be converted into Walls, Slabs etc.
It then cannot be modified by the Wall Tool, but you can place Doors and Windows in it and displays and schedules correctly.
If the geometry changes, you update the Wall etc. based on the new shape of the Morph face.
It is based on the premise that you create a building Mass with the Mass Tool, then convert the surfaces of the Mass to Walls, Slabs, Roofs and Curtain Walls. Also, generate Slabs based on the geometry of the Mass at the floor levels of your stories automatically.
Maby TMA_80 was referring not to workarounds but to integrate natively the morph tool into classic construction elements .
First the morph tool must be composite like walls and other construction elements .
This is more useful if you have complex or composite walls and the same sandwich structure into the morph tool structure , they must connect intelligent in 2d like walls do .
Practically the morph volume become a real wall with all attribute but with non standard geometry .
I admit that applying standard wall accessories to a such wall is not possible because his geometry .
How?
Sasha wrote:
How?
Sorry, from my reply it was not clear that I was also wishing. I modified my post so it is not ambiguous.
Exactly! I thought this was a feature in 16 already, but apparently not...
That is, from the webinar that showed the development of the massing model of the library, I thought they converted the morph...
I would like to be able to convert elements (polygons) that I have individually selected to become "roof" or "wall" or whatever elements, as appropriate.
i am joining to this wish
I would find this useful.
Morph should give the possibility to be used as a "massing" tool, and then be quickly transformed into a wall or curtain wall.
But the guys should rewrite the code behind walls and curtain walls so that won't happen anytime soon.
