Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Cores for Cinerender
alemanda
It would be very useful to set how many core have to be used by Cinerender. I wish it as option in the rendering settings.
It generally uses the max available number of cores but limiting it could be useful to continue to use the PC for other purposes ... especially when many cores are available ...
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
4 REPLIES 4
Erwin Edel
The windows taskmanager can do this, as far as I know.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
alemanda
Yes but it seems that every time you launch a rendering process it resets to the max value of available cores ...
Win 10 Pro 64bit
www.almadw.it
Erwin Edel
A quick search shows that cinema 4D seems to have a setting for this, so I suppose it should be able to implement it.
www.leloup.nl
Windows 10 Pro
alemanda
Maybe there a registry key value to be set for that purpose...
Win 10 Pro 64bit
www.almadw.it
