Wishes
Create Elevation shadow diagram on neighboring buildings
I wish there was a way to create an elevation view of a neighboring building to show the shadow impact of the proposed building. This is very easy to do in a perspective view but impossible in a 2d elevation view.
The reason for this is because the elevation view clips and disregards the information behind it. If there was a toggle in the view settings that enabled the view to consider the geometry behind the view as well as in front it would be magic.
I have attached a jpg that hopefully illustrate the issue.
view 1) is a perspective that successfully shows the shadow impact from the building behind.
view 2) is a 2d view at the same time of day of view 1 but notice no shadow from behind.
2 REPLIES 2
alemanda
In general I wish Archicad implement the option which consider the "effects" of clipped 3D portions without showing them. Useful also in 3D clipped perspectives
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Hi, even though I agree with this wish, there is also a way to do something like you want, not with all the options of an elevation but you can get the effect with a 3d document. At least is a temporary solution.
Learn and get certified!
