Wishes forum
Create SEO connection between only elements that intersect
This is a wish I thought of after reading Matthew Lohden's post about SEO.
http://archicad-talk.graphisoft.com/viewtopic.php?p=137834#137834
Let us say you have a lot of light fixtures and several slabs and want to cut out the light fixtures from Slabs. Select all light fixtures and all Slabs and execute the Solid Element Operation.
I am wishing for a checkbox in the SEO Palette with a name similar to this:
Create SEO relationship only between element that physically intersect.
What this would mean is that a SEO relationship would be created only between those light fixtures and those Slab that actually physically intersect in the model when the SEO command is executed. This would create much less SEO relationships, would keep the 3D Model cleaner and would be much faster to do than spending a lot of time selecting Slabs and only those light fixtures that have something to do with those Slabs.
The whole thing could be done in one step.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
11 REPLIES 11
Hi Laszlo,
I like it...
I like it so much that it should not only be within the SEO operations...
Why not add another criteria for the search and select tool?... Like... "Elements that intersect"...
In the end it would be available with the SEO... and many other situations...
What do you think?...
Yes, even better.
A good ides should be implemented as widely as possible.
And this concept could be extended to schedules!...
With this criteria you could create a schedule that shows intersections between specialities...
Structure vs Electrical... Structure vs Plumbing... etc...
Great idea Laszlo!
Erika Epstein
the MEP modeler does this. You can do clash analysis with it. Not yet the elec. v. plumbing but that I understand in the pipeline (all puns intended)
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Just a little comment. Relationships between elements in 3D word are hard to detect and analyze. It is well known point. But how can we dream about 3D detection in ArchiCAD, if it can't detect 2D relations properly! Even very simple situations on your plan can produce serious problems in automatic zone detection. Sometimes I think that ArchiCAD is BIM, but not CAD really
I don't know much about MEP and how it works in the AC environment...
But if it can do clash analysis maybe this criteria/function would not be that difficult to implement...
Or this analysis works only for the MEP objects?...
Erika Epstein
I don't know the technicalities. It is as though something in the MEP modeler parts can tell when they intersect with another 3D element that does not have the MEP coding.
It creates a list of clashes in the mark-up tool. From there it takes you right to the clash and the clash elements are highlighted.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
I thought that you ideas were based on MEP modelling tools. I guess that it should be a rather limited solution. For connected systems of pipe-like objects and other simple objects as wall, slabs etc. I'll be surprised if MEP modeller handles pipes as objects with round cross-section. And analyzes time should grow quickly with increasing of model complexity.
And remember zones! Did you read anywhere that ArchiCAD isn't an area-detection tool? No, it is full-functional BIM software! Look at any ads...
And this feature works with intersections between MEP objects and... lets say... walls, slabs, columns, etc ?...
Edit:
Ok... I took a look at the MEP presentation and... yes... it can detect clash between MEP objects and all AC elements...
So... if it can do this... It should detect geometry intersections between AC elements, right?...
Erika Epstein
Paulo,
If I understand correctly there is the potential for all archicad objects to detect clashes between themselves. Someone from Graphisoft would know the real answer.
But, I would think you would need to find a smart way to implement this feature. That 3D objects can now overlap without it causing a warning is a good feature to keep. Most users don't model that perfectly and /or sometimes intentionally let objects overlap. Would you want to be sorting through every clash? Potentially yes, but how about the Flowers in the water in the vase? Or Conrado's gazillion columns in his mesh?
In MEP they detect clashes between systems; one sets of objects v. another set. It would be good if we could assign objects to user-defined sets.
Or___?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika,
Thank you for your feedback.
If this criteria could be integrated in the search & select tool it would work with other existing criteria...
So if I would need to detect clashes I'd need to narrow the search...
In my example "Structural vs plumbing"... I'd first add 2 layer criteria... The Structural layer and the Plumbing layer...
At first... Just this would prevent lots of inappropriate clash collisions...
But then there was a problem... For example... I have lots of pipe objects that clash between themselves...
Even if they were in the plumbing layer... the gazilion clashes would still be detected...
I guess that your " user-defined system sets" could be the solution...
First you would need to define an unlimited number of "System sets"...
And AC would handle all the elements in the "System set" as a single geometry...
That would prevent those unwanted clashes...
But this would need a more elaborated criteria in the search & select tool...
Like a drop down... or perhaps a new tool...
My hunch is that this is viable...
But as you said... only the GS software team could put light over this matter...
p.s.: I thought about the clashes between elements in the same layer and came up with an idea...
Why not a "Clash filter" in the clash criteria?...
With this parameter... the clash detector could ignore clashes between elements with the same layer, ID, Material, etc...
