Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Curtain Wall Divider
ravelandrade
Please, add a tool to make it easier to split curtain walls, just like we can use Ctrl + Click to divide lines, walls, beams...
runxel
Legend
There is already a special tool for this. Not sure why GS couldn't just put it into the normal split function, but there is "CW split". Works only in floor plan, if I recall correctly.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
And it only splits a curtain wall with another curtain wall.
So you need 2 intersecting curtain walls.
Oh yeah.... "minor" detail I forgot to mention 🙈
The CW spilt tool is erratic at best, because the actual split won't take place where those 2 CWs meet either....
Basically it's garbage and we really need the consistency. The split tool should work for everything in every view (so long as it makes sense ofc).
