‎2022-08-23 05:00 AM
Please, add a tool to make it easier to split curtain walls, just like we can use Ctrl + Click to divide lines, walls, beams...
‎2022-08-23 04:55 PM
There is already a special tool for this. Not sure why GS couldn't just put it into the normal split function, but there is "CW split". Works only in floor plan, if I recall correctly.
‎2022-08-24 03:37 AM
And it only splits a curtain wall with another curtain wall.
So you need 2 intersecting curtain walls.
‎2022-08-24 02:23 PM
Oh yeah.... "minor" detail I forgot to mention 🙈
The CW spilt tool is erratic at best, because the actual split won't take place where those 2 CWs meet either....
Basically it's garbage and we really need the consistency. The split tool should work for everything in every view (so long as it makes sense ofc).
