Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Curved ramp 23 to be more flexible
Yvonne
It would be good if we can adjust where the gradient is measured i.e. the inner curve.
It currently only measures it from the centre
Also if there were nodes as well in plan to easier adjust dimensions etc
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you very much for creating this poll to share your idea!
I am happy to say we took notice of this wish and I have added it to our Wish List database (please refer to it as Wish #12975). Hopefully, our Product Management team will adopt this one in the future.
Thank you all once more, and I wish you a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Hi @Minh Nguyen,
Just wanted to highlight this type of ramp configuration (see image below) mainly used for Articulated Vehicles (those 40 footer trucks) so far the Straight Ramp within Archicad works perfectly where you can assign the gradient and all. The Curve Ramp falls a bit short in this area if it can have this flexibility it can be more useful for those who are working with industrial projects and required to have this kind and shape of ramp. It with be also helpful if you have Auto Turn built in within Archicad. Currently we are exporting are drawing to dwg and using auto turn I feel its a waste of time. Thanks! 😎
In the end what is your Objective?
ArchiCAD 9 onwards
