2018-09-21 09:03 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2020-07-13 01:55 PM
2020-07-14 05:22 AM
2021-11-05 04:27 AM
Looks like we have got the attribute reindexer in AC 24. Now we have a problem of limit of the number we can apply to a custom attribute index number. 32767. This is the maximum number of elements in a GDL array. Funnily enough it appears that the issue I am having applies to elements that are based around GDL.
I have been trying figure out a way to sort attributes using an index number based of a classification system number like Uniclass 2015 or MasterspecNZ. For example in MasterspecNZ Concrete 3121 so a building material of concrete in-situe would have an attribute index number 312101 so if I need to add additional surfaces or building materials then they can be added within the same number range 3121. Currently there is a limit in the number that can be used which is 32767. I need to do this because I need to make sure across a range of files that the attributes of fills, surfaces and building materials are always consistent. I need to know that the expressions for take off that I am writing will always point to the correct attribute. Failure to do so will mean inaccurate costings.
