Wishes
Custom property into Zone
I wish to put my own custom property into Stamp Zone
Today I had to put a Label to do this
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
This is already possible to do.
For example, in AC21, the "Zone Stamp 02 21" Stamp can display any of the element Properties defined in the Property Manager, including your custom Properties.
In the Settings panel of the Zone Settings Dialog, select "Classification and Properties" as one of the items to be included in the "Content Order" page of the panel. Then in the "Classification and Properties" page of the panel you can select which Property should be listed.
It possible with AC20 too by the Stamp 02
I've asked and search since a long time without result
Thanks a lot
Christophe - FRANCE
It it's bit hidden. If you add rules form IFC Shemes it is super powerfull tool for showing different data.
