Jeffrey, you CAN define pens within objects if they have been scripted to do that. Most of my objects have one or more pen definition parameters, depending on object complexity.
There is also always an option to either use the objects pens, i.e. those definable by parameters, or not to use the objects pens, in which case you can still select what single pen you want to use for the whole object.
cheers
Daniel
Daniel Lindahl Architecture
AC24 | Dell Inspiron 16+ | Windows 11
