2017-07-27 04:25 PM
2017-07-27 05:11 PM
2017-07-28 12:06 PM
Piotr wrote:Really ? I'm not sure...
They reset on the close of the program.
They can be saved with a view.
Best Regards,
Piotr
2017-08-03 03:03 PM
2021-10-19 08:19 PM
Seems this has been asked before.
Is there a way to save and name orientations?
I'd prefer this to be in the Project Map, so I can switch between views and maintain the particular layers and scale I working in.
2021-10-20 03:34 AM - edited 2021-10-20 03:34 AM
Yes there is, but it does not seem obvious - but it works.
Set the orientation and zoom factor you want.
Now go to the zoom button and 'Save Current Zoom'.
This also save the orientation so I just discovered.
2021-10-20 12:45 PM
Thanks.
2021-11-16 11:54 PM
I just found a way to delete unwanted orientations, by creating new ones that make sense. I found the same problem as you when setting up the template, as there was one saved orientation that I wanted to remove.
It turns out that Archicad will only save the last 4 orientations, so by defining new ones that make sense, you can delete the old ones.
See image below to the ones I have created to complement the standard ones:
