Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Delete saved orientations
felcunha
In Archicad we can rotate the 2D views to other angles than the default orientation: by default it proposes orthogonal orientations (0°, 90°, 180°, 270°) but we can rotate the view to any other angle.
These different angles are stored in the orientation view list for easy retrieval.
The problem is when we have lots of different orientation angles listed in and we don't want all of them to be stored.
So it would be nice to :
- delete unwanted orientation angles, and/or ;
- name them like AutoCAD named UCS...
Felipe Ribeiro Cunha
AC 26, macOS Monterey
7 REPLIES 7
They reset on the close of the program.
They can be saved with a view.
Best Regards,
Piotr
felcunha
Best Regards,
Piotr
Really ? I'm not sure...
I've closed the file and reopened it, the angles were still there !
To be able to name the rotation angle of the view a n d to save them in project file would be nice unimportant if it is saved in the associated view.
Johann_P
Seems this has been asked before.
Is there a way to save and name orientations?
I'd prefer this to be in the Project Map, so I can switch between views and maintain the particular layers and scale I working in.
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
Yes there is, but it does not seem obvious - but it works.
Set the orientation and zoom factor you want.
Now go to the zoom button and 'Save Current Zoom'.
This also save the orientation so I just discovered.
Johann_P
Thanks.
Windows 10 Pro
Tormenta4
I just found a way to delete unwanted orientations, by creating new ones that make sense. I found the same problem as you when setting up the template, as there was one saved orientation that I wanted to remove.
It turns out that Archicad will only save the last 4 orientations, so by defining new ones that make sense, you can delete the old ones.
See image below to the ones I have created to complement the standard ones:
Archicad 25, MacBook Pro M1 Max, macOS Monterrey.
