2004-12-10 09:22 PM
2004-12-11 12:39 AM
2004-12-12 12:58 AM
Dwight wrote:I find this option pretty useful but wish it could be staggered like the main section line
Play a little with the "marked distant area" control in the section dialog and see if this works for you.
2004-12-15 09:21 PM
For every 10' distant (up to end of section extent) subtract 1 from pen numberYou could do the same thing for rows of pens, if you use colors 21, 31, 41, 51 etc, adjust it to be "subtract 10 from pen number."
CUT line = .50mm, Cut Skin = .25mm, FOR each 10 feet, subtract .125mmWhatever the final logic, it would need to be variable based on how offices use pen colors, but still allow for massive variation in depth. The current "distant override" is a nice start, but still needs some work to achieve the "professionally drafted" look architects desire.
2005-03-31 02:19 AM
