2003-11-03 11:11 AM
2003-11-03 06:46 PM
2003-11-03 10:07 PM
Karl wrote:Me too..., at least in my top 100
This has been one of my top 5 wishes for a long time. I keep sending it in.😉
Karl wrote:
Until we have linked 3D detail windows...with view settings that result in a proper import into PM (import from the 3D window is still all wrong in 8.1) ...
2003-11-04 03:19 AM
Geoffroy wrote:As a workaround, it still doesn't quite do the trick since you cannot annotate/etc as you would a detail.
You still can use the old "Publish as PMK" function, but that's really not satisfactory !
2003-11-04 08:28 AM
Karl wrote:You have to annotate in PlotMaker, but due to the poor text tools functionnalities, it's definitely not a satisfactory solution. And you can't add dimension lines...Geoffroy wrote:As a workaround, it still doesn't quite do the trick since you cannot annotate/etc as you would a detail.
2003-11-04 08:49 AM
Geoffroy wrote:I had to add a "metoo" to this wish, if only to push my membership status up a bit.
Having 3D details windows would be great, ability to add dimension lines, text and lines...
2003-11-04 08:57 AM
David wrote:Just as in Sketchup... 3D Detailing and dimensioning is an one of its impressive feature !
What would be great, since we're wishing, would be a detail window with a Piranesi-esque understanding of depth, so 3d dimensions could be easily added, surfaces could be shaded, notes could be written in perspective on a surface, etc...
2003-12-02 04:12 PM
