2021-04-18 12:51 AM
2021-04-21 05:33 AM
2021-04-21 06:34 AM
Barry wrote:
Then place just the door/window you want and then 'save as' an Archive file - try to delete everything else from the file so you have just a wall and a door/window.
Now when you open this archive file you will have the option of creating a library (i.e. not reading from the archive).
This should give you a library with the door/window and the required macros as well.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2021-04-21 10:41 AM
2021-05-05 12:39 AM
2021-10-13 02:43 PM
On the INT library, the "Store front" door gives you the option to have different door handles on a door.
2021-10-13 03:04 PM
Just checked my AC23 project using the Dutch localisation, we also have the option to check a setting for using the same handle or a different one for each panel for the standard doors.
