Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Dim moving / witness line stretching / units
1. Are we able to stretch the witness line in v17 manually any more?
2. The units are in eg "4.20" but used to be "420" in the settings. Can it be changed?
3. Auto dims spacing is now defaulted to 5 instead of 6. Can it be changed?
4. Can we soon be able to move dims as well as text in one operation?
Loving v17, regenerates piles of entities quicker on screen and also saves quicker
Thanks
Hey Dennis,
1. http://archicad-talk.graphisoft.com/viewtopic.php?t=43715
2. This could be your OPTIONS > PREFERENCES > WORKING UNITS
Mine is set to millimetres and I see 420 but when change to meters it becomes 0.42
You might be set to centimetres.
3. I'm not sure but if you change it to 6 and then save your job/template does it remember this for next time?
4. This would be nice.
1. Beautiful!
2. No luck but I'll keep at it (on mm atm)
3. I believe it did!
4. I've resorted to adding text to the dim label, wish it went below the line though.
Thanks Barry
Go Dockers!!!
