Wishes
Dimension delete warning
It would be very useful if AC would warn you if you have deleted an element that a corresponding dimension is about to be deleted too. With the proviso that the warning could be easily turned off by hitting the enter key (for example) and an option was provided to toggle it off altogether.
This wish comes about as a result of many instances of dimensions going missing because some CAD operators don't always have the dimensions layer turned on when editing/deleting walls etc..
Roolio
3 REPLIES 3
Djordje
Ace
Roolio
Even more dangeous is CTRL clicking; that is why I always, but ALWAYS go for Adjust if I am revising an already dimensioned project. And keep the dimensioning layers on all the time ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
This is SOOOOO true! Can't believe that in 9 years only 10 ppl voted this post and can't believe that Graphisoft hasn't addressed this issue.
At working drawings issued to site, any further change causes dimensions to disappear inadvertently which normally ends up in mistakes that the architect would have to bear.
Forget about printing the whole project to find the needle in the haystack of the missing dimension. Better off deleting them all and re-dimension the whole thing.
Seriously?
There's nothing better out there? I can think of various tools which could help to control this aspect. Can we have one that works?
Even if the layer that contains the dimensions is locked, by deleting the item that is linked to it, the dimension will disappear!??!
Thanks.
What would be handy is if the selection highlight of an element also highlighted the associated dimensions as well.
Like it already does in reverse - the selection highlight of a dimension (or node of a dimension) will highlight the associated element it is dimensioning.
Learn and get certified!
