Wishes
Dimension "standards" added to display options
It is essential that dimension "standards" be added to display options.
ABSOLUTELY ESSENTIAL.
We already have the capability to name different levels of precision, called dimension standards. Why can't they be linked to a display options? I know I'm not the first to wish this.
I don't know how all of you AC experts have details at one level of precision and your plans at another, but me, I have to MANUALLY!!! change my plan dimensions. Take a look at my plan dimensions. When I make a dimension manual I change its color to orange. HALF of the dimensions on my plan are manual!!!! That is completely unacceptable Graphisoft!!! Graphisoft, what method did you have in mind for us when we need a detail at one level of precision and the plan at another? Oh! You didn't think about it? Of course. I should have known that after 20+ years of designing a piece of software you can't figure this out on your own. I'm sorry. I suppose Graphisoft can't be expected to think of everything, especially the most common sense intricacies of Architecture, apparently.
You guys do have on staff Architects, right?
I make no apologies for my rudeness. When Graphisoft starts treating its customers with respect, designing a decent piece of software, I'll start being nice.
31 REPLIES 31
Geoff wrote:
So I would I would argue for the dimension standards to be defined and named in preferences then selected via pull down in the dimension tools themselves.
I would probably never change the precision or units of a given dimension element, so the display option doesn't seem right.
I don't think I need by-element control within a window, either. I think I could get by with a window-wide setting that could be saved with the view. Add it to layers, scale, DOs, zoom.
Alex is right about the seriousness of this issue. As with all manual workarounds, it's not just the extra work, it's risk of human error as the workaround is half-implemented or not maintained. With dimensions in particular this is critical.
PS, MHO,
Metric: Great system, lousy units.
Imperial: Vice versa.
James Murray
Archicad 25 • Rill Architects • macOS • OnLand.info
Geoff,
I think you may have misunderstood. The proposal as I understand it is not to make dimension settings into a display option nor to control their appearance through a new display option, but to use the existing list of named dimension settings in the same manner as display options, scale, and layer combinations. These dimension settings control the unit types and accuracy as you describe (along with a few bits like whether to show zeroes etc.).
This way you can set up one called "Survey" with decimal feet and surveyors units, one called "Floor Plan" with feet and inches at 1/4" accuracy, one called "Millwork" with fractional inches at 1/32" accuracy, as well as metric and so on. This function exists now, all I (we?) would like to see is to have it available as a pop-up like the display options etc in the Navigator and to become one of the things that can be set by the view.
Petros Ioannou
Since the topic became quite interesting I will write down my thoughts.
I agree with Matthew's "inch, foot and yard are nice human scale sizes". Colleagues who studied abroad told me that they found this system closer to human scale.
On the other hand if I measure something with my shoes, I am sure that someone will ask me to send him a pair of mine to verify the measurement!
Maybe we should take a look again to Le Corbusier's Modulor?
It was based on wrong maths, but he tried to bridge the gap between metric and imperial system.
Anyway I agree to a more flexible dimensioning system but not too complicated (Autocad comes to mind)
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
James,
What are you doing here at this hour on a Saturday morning? Oh... the same thing I am I guess.
Very good points. The core problem is that dimension settings are global. I agree that dimensions, once set, are unlikely to need to change and it would make me nervous knowing that ArchiCAD is running through the whole project changing all the dimensions every time I switch views.
The one problem I see with your proposal of window based settings is in plan where there is a site plan at one scale, layer combo, etc. along with one or more floor plans in the same window. Another question is stories; same window, different drawing.
I too am not sure that individual settings are the way to go, but it is beginning to look like it may be the cleanest and most reliable approach that addresses all the issues. I REALLY like the idea of dimensions that stay exactly as I put them. I still have dark memories of version 5 when all dimensions would be recalculated (including ones whose text had been edited) each time the units or accuracy was changed. (As I recall this was fixed in 5.1 so I don't think you ever lived this little nightmare.) I sure used a lot of static dimensions back then. It's also when I created my dimension string library part out of desperation.
I absolutely agree (with everyone it seems) that the dimension tools needs improvement it's just how to go about it that seems an open question. Whatever the answer it needs to be one clear, simple, comprehensive, and well thought out solution and not a collection of fixes and patches in various settings and places.
I am leaning toward the individual settings for each dimension and making the list of presets as no more than a handy way to set the defaults (and not reset the dimensions globally as it is now). But, hey, this way the presets could still change with the view selection in Navigator and we really can have it all (and eat it too).
So what do you all think: Is individual settings the way to go?
vfrontiers
For me it's easy... We need to have INDIVIDUAL CONTROL over BOTH accuracy and display for each dimension... Have you ever done INTERIOR ELEVATIONS? Clg heights often are dimensioned in FT & IN while cabinets are in IN in the same drawing. For me, there is no other way to do it.
As far as accuracy goes, I leave my dim's on 1/64 and make them work... Then comes a rotated grid and I have a line of framers pointing their nail guns at me! Typically I WORK in 64th (dims) until I am close to PLOTTING, then I choose the appropriate OUTPUT ACCURACY!
It's never gonna be easy!
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
I think ViewSets should include dimensioning (and while we are at it Working units settings)
I also think that individual dimensions should have the option to override current dimension settings with their own (nail it down)
Imperial units are source of a lot of idiosynchracies in CAD, but have to admit that from a contractor/ woodworker point of view, I adjusted, and actually learned to like the imperial system, and when given a choice, I used the "backward" fractional inch system. Not because the unit sizes, but because of the system. I comes down to division by 2 which is easy, instead of the 10th (2 and 5) which is not always easy.
by hand one can divide fairly easily by 2 and 3, but five is a little trickier.
as for absulte sizes go, mentally is fairly easy to adjust (like in rope sizes and plywood : 1/8 = 3mm, 1/4 = 6mm, 1cm = 7/16 (which is 1/2 inch less 1/16 about approx. 1 mm), 12mm= 1/2 inch.
1ft = 1/3 meter, etc.
wish the fahrenheit/celsius would become natural so easy.
I have a couple of spreadsheet patches created for practical uses: outdoor temperature ranges, body temperature ranges for quick judgements. Still, no easy replacement for the 0-10-20-30 degrees C. or the 36.5, 37, 37.5, 38, 40 deg C for measuring body temperature.
Hello
I cannot resist wasting a few minutes for that. Alex, do not call me just a Swiss narrow-minded guy, I spent (15 years ago, sorry for the English) 2 years following an arch master program in the US.
I agree imperial sys is nice for design but not for construction. I remember the congested faces trying to calculate in whatever semi liquid units the concrete volume of a 15x 10 ' piece of slab...
Accuracy of dimension are much more important in construction drawings and they have to be as homogeneous as possible in a plan.
But I agree that between plan level (site, preliminary, etc), we should be able to change the units. In Switzerland we will indicate a 15 x 10 m housing parcel but it is not a big issue for us, we can quite easy understand an UK 15000 x 10000 mm dimension (incredible, mhh?). So, as somebody asked, I did not vote, because the big problem is the fraction system. I think American architects miss the most important information. Wall Street moved from the fraction system quotation to a decimal one. How long will you resist? Who's the chief over there?
Piece of sarcastic remarks , I know but you scream a little bit too loudly Alex. Try autocad, an ....(complete the space) made product and you will know what is to work without any feeling of arch needs. Maybe GS as not enough Am arch in his staff... Next time try a Chinese or a Paki product, if they are Hung..ry enough, you might even insult them...
Erika Epstein
Matthew wrote:
Geoff,
short of going to metric ...YES YES YES
Could this work in the display options similar to the different ways doors can be shown?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
This is what I originally intended but after reading y'all's replies I believe it would be best if Dimension Standards be added to Quickview settings rather than display options.
Dave Jochum
Matthew wrote:
Geoff,
I like this approach also. I would also like to see an idividual override for any dimension by way of the pet pallette. Duane's interior elevation senario is a perfect example of why this would be necessary.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 13.5.2•AC 27 Silicon (latest build)
