I wish there would be a way to transfer non static dimension lines between structural displays. Now we have to dimension the entire building 2 times as we need one for core only and one for finished wall.
This is a huge time waster especially if your building is big.
Ideal situation:
1. Do the dimensioning in the wall with finishes, select, copy.
2. Switch structural display
3. Paste dimensions and click OK on a warning message that: "Your dimensions will be adjusted to structure cores."
