Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Display IFC properties of elements with Label Tool
Simple example: very often we have to show the fire/acoustic rating of walls on floor plans and sections - a very convenient solution to this would be if the Label Wall tool could be linked to the IFC properties of the walls.
I strongly agree with this wish.
Not only for accoustic and fire rating, it is also convenient when we import IFC model from structural and MEP engineers.
The Label Tool should be made able to display all kinds of parameters of elements. I thinkthe Label Tool in general should be able to display any parameter you can schedule. You can schedule many element parameters, any parameter of GDL Objects and any IFC parameter of elements.
Then we would have a really powerful and versatile Label Tool.
owen
Essential .. but i think implicit in this wish is that GDL is generally able to write to/from/with IFC parameters. It could be Read Only (i.e REQUEST functions) as a first step, but ideally you should be able to write IFC parameter values from within the GDL script of an element (e.g where an object is capable of representing variations of a product family)
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
