Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Display of Window/Door Opening Lines
Laura Yanoviak
The display of window/door opening lines should be controlled by Display Options (instead of/in addition to the objects' parameters). Typically, whether or not one wants the opening lines to appear is a function of the drawing type, not the individual opening.
AC26 US (5002) on Mac OS Ventura 13.5
12 REPLIES 12
Rob
it is actually a good point. Showing the opening lines should be in the global settings...
::rk
AND TO CHANGE THE OPENING DIRECTION ON IN THE INTERACTIVE SCHEDULE PREVIEW WINDOW
More options are better, so I say in addition to the current options is the way to go.
I would also like to be able to show the swing of casement windows in my floorplans which I currently cannot do. The diea is to make the swings look like the doors do, so my installers will easily see which way the casement window is supposed t o open without having to refer to the elebvation and run the risk of having a transposition error.
Laura,
Just to clarify even though our friends in Budapest have remarkably good English skills: you're talking about opening lines in section/elevation, right?
If so, I agree... a display option would be great.
One of the forum moderators
Laura Yanoviak
Correct. The name of this parameter is "Opening Line in 3D".
But where in AC13 do I find display options?
Erika Epstein
MVO
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Duh,
Thanks Erika.
It's simple when you know how.
woodassoc wrote:
Duh,
Thanks Erika.
Sorry to be so out of touch, but... what is MVO ?
