Wishes forum
Display of Window/Door Opening Lines
Laura Yanoviak
The display of window/door opening lines should be controlled by Display Options (instead of/in addition to the objects' parameters). Typically, whether or not one wants the opening lines to appear is a function of the drawing type, not the individual opening.
MacBook Pro 2.4 GHz Intel Core i9, 32 GB of RAM
AC25 US (3011) AC24 on Mac OS Catalina 10.15.7
12 REPLIES 12
Rob
it is actually a good point. Showing the opening lines should be in the global settings...
::rk
AND TO CHANGE THE OPENING DIRECTION ON IN THE INTERACTIVE SCHEDULE PREVIEW WINDOW
More options are better, so I say in addition to the current options is the way to go.
I would also like to be able to show the swing of casement windows in my floorplans which I currently cannot do. The diea is to make the swings look like the doors do, so my installers will easily see which way the casement window is supposed t o open without having to refer to the elebvation and run the risk of having a transposition error.
Laura,
Just to clarify even though our friends in Budapest have remarkably good English skills: you're talking about opening lines in section/elevation, right?
If so, I agree... a display option would be great.
Karl
One of the forum moderators   •   AC 26 USA and earlier   •   macOS Ventura 13.2.1, iMac Pro 10-Core, Radeon Pro Vega 64
Laura Yanoviak
Correct. The name of this parameter is "Opening Line in 3D".
But where in AC13 do I find display options?
Erika Epstein
MVO
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Duh,
Thanks Erika.
It's simple when you know how.
woodassoc wrote:
Duh,
Thanks Erika.
Sorry to be so out of touch, but... what is MVO ?
