There are two problems I can see when using MVO's to control object parameters.
One is each object should have an option to over-ride the MVO setting.
I have scripted in my object a "Use MVO setting (on/off)" parameter so I can take individual control of an object.
The other is that we need to have object parameters controlled globally but not have to save them in an MVO scheme.
Just imagine you have 10 schemes or more to produce various types of drawinging from the one model. (I know 10 is a bit much but just trying to stress the point).
Every time that you want to change one of the global parameters you will have to redefine each MVO scheme to include that setting.
It would be far easier to have the choice of using an MVO global parameter to change things that are important for different types of drawings or just a model global parameter that stays set no matter what MVO scheme is in use.
