Wishes forum
Display order enhancements
I would like to be able to see where in the 14 possible layers of graphical stacking order an element currently sits.
A drop down box in the settings dialog would both indicate what stack level it is on and allow you to manually set the level.
Also when you hover the mouse over the element, the tracker popup should display the stack level for quick reference and allow you to edit it manually too.
These would be less useful if ArchiCAD actually used a height based draworder system where an element that was higher in elevation than another correctly obscured the lower element. It seems odd that it isn't set this way already.
Perhaps the best way would be to disable the draworder adjustment for 3d elements in the above case, but still allow 2d elements to be adjusted in order to correctly use cover fills etc. In which case they should add a 'send above element' or 'send below element' option too, for a faster workflow.
11 REPLIES 11
Laura Yanoviak
There is an add-on that does this: OBJECTiVE
and I've considered puchasing it for this feature alone.
MacBook Pro 2.4 GHz Intel Core i9, 32 GB of RAM
AC25 US (3011) AC24 on Mac OS Catalina 10.15.7
Link
Below is a quick wish I submitted to GS back in the early AC9 days. It's a bit rough but the point was that we needed a clearer idea of where elements are at in the display order.
The height based display order is obviously the best solution!
Link.
Laura Yanoviak
...and there is this...
Wish Peter Clark, fairly. I can assume, why it has appeared.
Roof, Column, Wall, Slab, Mesh with an identical index of a priority.
At Lamp, Stair, Library Object the priority is higher than at Roof, Column, Wall, Slab.
It adds work (at least, me).
At Roof the priority, than at Column, Wall, Slab should be higher.
At Column, Wall, is higher than at Slab.
At Lamp, Stair, Library Object is lower than at Column and Wall.
My reasons are those.
An add-on 2nd to none!
Up!!!!
Mac OSX 10.15.7 | AC 24 INT 5000 FULL
Rob
I think this would not be necessary... if we had options:
In Front of [click element]
To Back of [click element]
::rk
That would be nice too. Problem is when you have elements showing on multiple storeys it may be confusing.
I would much more prefer a solution with display order organized numerically in the fashion of layer priorities.
Erika Epstein
Great idea, as adjustments are typically between two elements.
Always a binarist our Rob.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
OBERMEYER
We're five projects into Archicad and one year experience and just now learning how display order can be a serious annoyance. I'm surprised to see this message thread end in 2011. The issue still seems relevant. Has Graphisoft made some improvement as 'wished for' in the previous posts over 4/5 years ago? Am I missing something? Or do we still not have an 'out of the box' (no third party purchasing required) solution to make display order stacking less of a mystery?
In our case simply adding arrows to show direction of roof slopes is a tedious task. Sometimes they're on top, sometimes we have to dig for them (display order stack). Even leaders sometimes are covered by roofs or slabs or walls. Why would anyone ever want a leader covered by the model elements?!!!
Is this just another sad behavior that other successful Archicad users have become accustomed to in their workflow?
Andrew Obermeyer | Architect
OBERMEYER Architecture
www.obermeyer.la
AC 24 USA | Windows 10 | Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz | 32GB RAM | NVIDIA Quadro P1000
Jeff Kogut
I use a mostly stock work environment but one of the few changes I make is to assign the following:
Bring Forward = up arrow
Send Backward = down arrow
Not exactly what this wish is going for but it works quickly.
AC19-23 | Win10 Pro | i7-8700K | Quadro P600 | 500gb 960 EVO M2 | Dual 28" 4k Samsung U28E590
Labels
