Wishes
Do you think "Archicad SOUNDS" need an update?
Stress Co_
This wish is for an update to ARCHICAD sounds:
- Give us control of what sounds are associated with each "alert".
- Give us the ability to turn SOUND on/off for each "alert".
I want to hear Teamwork alerts, but don't really need a "BLEEP" every
time I rotate my model in the 3D window.
- A separate volume control for alerts would also be welcome.
I like my music loud (played via my Mac), but not so much for the alerts.
- At the very least, code "enable/disable ARCHICAD sounds" as a
command that we can add as a keyboard shortcut or toolbar icon.
It sucks having to open Work Environment to switch it on/off
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
5 REPLIES 5
Hello Stress Co,
You are able to switch ".wav" files into your application files to change alert sounds.
I always think about it, it is a great idea !
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
Stress Co_
Bonjour Christophe:
Where do those files reside? (You're using macOS, yes?)
All I could find was some .aiff files in the system-library-sounds folder.
Hello Stress Co.,
Archicad 24/Contents/Ressources
To open Archicad you have to di a right clic and select open "show package contents"
You will find any wav files into Ressources folder
It is the same way on Windows devices.
Christophe - FRANCE
Nader Belal
Mentor
I totally support that request, for many times I tried to push on that issue
Stress Co_
To open Archicad you have to do a right click and select open "show package contents"
You will find any wav files in the Resources folder
Thank you for that Christophe.
That's better than nothing.
